Shingle Ripper – Cut or pull nai?
MikeK | Posted in General Discussion on July 3, 2007 12:03pm
I’m getting conflicting advice on the use of a shingle ripper to remove cedar wall shingles.  On guy told me that you hook the nails than bang on the ripper with a hammer to cut the nail. Next guy told me ripper is supposed to pull nails out, not cut them. Who is correct?
Mike K
Old House Remodeler
Aurora, IL
  1. kate | Jul 03, 2007 12:15am | #1
    Kind of depends on the condition of your shingles...some cut, when the wood is sound, & some rip out, when it isn't.
    You also need an end cutter or nipper to pull out the rest of the ones that cut off.  Or you can drive them in the rest of the way.
    Good luck with your project!
    Sphere | Jul 03, 2007 12:52am | #2
    SLATE ripper. Cuts Copper nails. Generally pulls steel.
  3. Piffin | Jul 03, 2007 02:29am | #3
    both.
    Best if you can pull the nail down with the hook, but sometimes all that does is break the head off as it bends the nail so you can't get it again, then you turn to the cutting tip. The tool is made for both possibilities so neither one is right enough to win a bet.
Choosing a Paintbrush
  • The New Old Colonial
