Shooting finish nails into MDF
YZguy | Posted in Construction Techniques on February 3, 2005 12:39pm
Got a problelm with shooting finish nails into MDF.  the nail sinks below the surface, but a nickle-size bump grows around it.  my pressure is set to 90psi (i’ve tried higher and lower) and i am shooting into either wood or drywall behind the moulding -both give the same result.  thanks for your consideration, T
    IMERC | Feb 03, 2005 01:01am | #1
    up the pressure anothe 10 pounds... shoot the nail... shave the bump off with a sharp chisel...
    quit using MDF...
    proud member of the FOR/FOS club...
    WOW!!!   What a Ride!
    1. zendo | Feb 03, 2005 01:36am | #2
      buy a hitachi finish nailer.
  2. Frankie | Feb 03, 2005 01:42am | #3
    You need to use a brad nailer which will minimize the hump. Then shave the hump with very sharp chisel or plane. BTW, this shaving will change the surface texture and accept paint differently. Be sure to sand area after priming.
    F
    skyecore | Feb 03, 2005 06:12am | #4
    ive a good labor saving method! used by virtually all MDF pro's.. Lower your standards
    ______________________________________________
    --> measure once / scribble several lines / spend some time figuring out wich scribble / cut the wrong line / get mad
    JeffBuck | Feb 03, 2005 10:55pm | #5
    "but a nickle-size bump"
    Nickle sized?
    what kinda framing nails are ya shooting in?
    I regularily shoot 15 g's thru my Senco nailer ... very little mushrooms.
      Buck Construction
       Artistry in Carpentry
            Pgh, PA
