shooting finish nails through plaster
square | Posted in Construction Techniques on November 20, 2003 03:58am
I am in the  process of installing new windows in a house that has plaster walls. Plaster is about 7/8″ thick, more or less. Will 16 gauge finish nailer shoot through 3/8″ oak casing and plaster?  Will plaster blow out? Any helpful advice out  there?
Thanks for the help, fellow woodpeckers.
    AaronRosenthal | Nov 20, 2003 04:34am | #1
    Mine will. I have a Paslode finisher 16 ga. I use 2" nails into plaster & lath, no sweat.
    I don't know about your plaster for blow-out. I've found that if it's in good shape, plaster does not usually crumble under a gun.
    Quality repairs for your home.
    Aaron the Handyman
    Vancouver, Canada
  2. RalphWicklund | Nov 20, 2003 04:35am | #2
    You'll be all right. You could even hand nail (ha, ha)
    Even if there is a little blow out you'll never see it because the weak side of the plaster is against the window bucks, well hidden from the outer edge of the casing.
  • A Postwar Comeback
