Shop Floor Epoxy Source in Phoenix
daen | Posted in General Discussion on May 5, 2009 02:51am
I am planning to epoxy coat my concrete shop floor. I live in the Phoenix metro area (East Valley). I was hoping someone in this area might have some first-hand experience and vendor suggestions. Who did a good job and who to steer clear of.
Thanks,
-dch
  1. seeyou | May 05, 2009 04:05am | #1
    bump
    http://www.quittintime.com/      View Image
  2. alwaysoverbudget | May 05, 2009 04:16am | #2
    i'm not sure if you want labor also or what,but i'll bump you up .
    check sherwin williams and ask about there moisture cure floor paint. my opinon is it blows the expoxy out of the water. of course your in the "dry heat " so maybe they don't use it there.
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    1. daen | May 05, 2009 07:23am | #3
      I am looking for a company to do the job. They supply the material, do the prep and application... and try to avoid warrantee claims later.
      -dch
        Dam_inspector | May 05, 2009 01:35pm | #4
        Go where the pros buy materials and see if the store can give you a lead. It seems that sherman williams is a popular place.
