Shop Vac parts
MRockwell | Posted in Tools for Home Building on September 8, 2009 04:30am
The on/off switch on my shop vac died, and I’m having trouble finding a new one.  I’ve been to the Shop Vac site and when I enter the model# it comes up with nothing.  It’s a model QPS35, and even on Google I’m having trouble finding info.
Anybody have a good source for parts?
Mitch
www.rdwoodworks.com
http://www.freewebs.com/glenndalepedalplane/
    PeterJ | Sep 08, 2009 04:50pm | #1
    Got a pic of the switch? Probably not proprietory,  try electronics supply, maybe Grainger?
    1. MRockwell | Sep 08, 2009 05:15pm | #2
      No picture at this time, but it is a double pole single throw rocker switch.
      The rating on it is 15A at 125v  and 12A at 250v.  I checked Grainger first thing and couldn't come up with a switch with those same ratings.
      Mitch
      http://www.rdwoodworks.comhttp://www.freewebs.com/glenndalepedalplane/
        PeterJ | Sep 08, 2009 05:27pm | #3
        Here's a couple, anything like this?
        http://www.mcmelectronics.com/search.aspx?C=&K=rocker%20switch&T=
        PeterJ | Sep 08, 2009 05:31pm | #4
        More possibilities
        http://www.mcmaster.com/#rocker-switches/=3jj2gv
        Are we gettin' close?
        1. MRockwell | Sep 08, 2009 05:51pm | #5
          I'll check those links out, thanks.   I just got an e-mail back from ShopVac, and they want me to buy a new power unit, Ha!
          Mitch
      3. MikeHennessy | Sep 09, 2009 02:46pm | #12
        "double pole single throw"
        You sure about that? I never saw a double pole switch on a 120v machine. My guess is that it's a single pole, single throw. You could probably pick up something that'll work at a hardware store or Radio Shack.Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
          Dam_inspector | Sep 09, 2009 02:54pm | #13
          It probably is a double pole switch. Sometimes one set of contacts goes bad and you can just short the bad one out for a little more use.
  2. bd | Sep 08, 2009 08:44pm | #6
    Why not just call them to see if there is a substitute?
    Phone: (570) 326-0502
    I've had them send me some parts that I've broken for free.
    1. mms | Sep 08, 2009 09:04pm | #7
      If you can't get a switch to fit, you could wire it to be always on, and plug it into a power strip to control it, or add a switch to the power cord.
  3. webby | Sep 09, 2009 12:19am | #8
    I think iirc I have ordered a part from these people. Good service. I ddint see a qsp 35 but a qsp 30 and a 400 hangup. Might use the same switch. Look at the schematic. Some have part numbers for switches some don't.
    http://www.vacshopusa.com
    Go up to vacuum parts, then down on the left to shopvac, then to shopvac schematics. Site is kind of confusing.
    Webby
    Edited 9/8/2009 5:23 pm ET by webby
  4. KenHill3 | Sep 09, 2009 12:39am | #9
    Yup. Forget the switch, do a bypass and add an inline switch.
  5. MrBill | Sep 09, 2009 04:37am | #10
    Mitch,
     I second the idea of calling them. I just got a new switch from them for mine, all it took was a phone call.
     Personally, I hardly ever use e-mail for this type of thing. I find a phone call is the quickest and easiest way to do things.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
    1. MRockwell | Sep 09, 2009 04:49am | #11
      To All: Thanks for the responses.
      I think I will give them a call tomorrow, 'cause there is no way I'm going to buy a whole new power unit when all I need is a switch.   It ticks me off that a company can't(or won't) provide a simple solution to a simple problem.
      I did find out the switch is a Molveno, and found a spec sheet online....but I don't read Italian.
      Mitch
Drafting the 2027 IRC
  • The New Old Colonial
