Should I vent my overhangs on a non-vented roof
bandini | Posted in Energy, Heating & Insulation on December 4, 2013 07:40am
I am doing a non-vented roof on my house in Nashville Tennessee.  It has large 3′ 6″ overhangs. Should I vent them even though the roof is not?
  1. JimB | Dec 07, 2013 08:40am | #1
    Not sure what you are asking, but if you are insulating the
    roof, rather than the ceiling to create an unvented attic, then venting the overhang would allow outside air to enter the attic.  At least with typical construction.
    1. kxm1 | Feb 01, 2014 03:09pm | #3
      yes ...
      you should vent your soffits-continuous if possible, aluminum panels are the best...and most expensive!
      Why are you not venting the ridge?
  2. DanH | Dec 07, 2013 09:34am | #2
    If you're saying the eaves are boxed in and don't "communicate" with the attic area, I'd be inclined to install some small vents -- eg, the circular 2" ones, one or two in each rafter bay.
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
