shower base
montee | Posted in General Discussion on March 11, 2009 05:35am
I am looking for a 30 by 48 inch shower base. The big stores don’t stock it. This sounds like it is going to be a custom order. Does anyone know of a manufacturer of one? It is a small bath 5×8. Trying to replace an existing 30x 60 bathtub to gain a little space for nicer sink. Have another full bath so we are willing to live without another tub. Not planning on changing layout of bathroom or move plumbing. Any help would be appreciated.
Mike
  1. CCI | Mar 11, 2009 05:51pm | #1
    I recently got a Swanstone base pretty close to that size if I remember correctly.  It was special order thru HD and only took like a week or so.  Check swanstone's website for sizes.  Mine has the drain hole in the center - I don't know if they are available with the drain hole on the end in a smaller size than the 30"x60" bathtub replacement size.  If you can get the drain on the end it will save some plumbing expense.
  2. MSA1 | Mar 11, 2009 08:45pm | #2
    Why not just make a custom curb? You might find a 32"x48", do you have an extra two inches?
    1. montee | Mar 11, 2009 11:49pm | #3
      unfortunately poor layout does not really allow the two inches because of door swing and small bath demensions. didn't want to move plumbing lines but will consider if all else fails. I have a chimney chase behind my existing tub wall which prevents me from using appx. 20 inches of bathroom space. So i am trying to work around this.
      1. atrident | Mar 11, 2009 11:56pm | #4
          Look at the Schluter stuff. Its a bit spendy but is easy to do custom jobs.  You will have to mix some thinset and spread it, but I cant imagine an easier way to do it.
      2. MSA1 | Mar 12, 2009 04:33am | #14
        Would you benefit from dropping the chimney and installing B-vent? I did this before and gained 75% of the chimney space.
        1. montee | Mar 12, 2009 04:47am | #15
          Probably would however would take some serious consideration.
          mike
  3. YesMaam27577 | Mar 12, 2009 12:41am | #5
    Its been a few years, But I dealt with Laurel Marble and Tile. As i recall, they are somewhere near Atlanta.
    They have numerous "standard" sizes and shapes, and the capability to custom make any size. And they can do a perfect match of the color of the tile you'll be using for the surround.
    Not cheap.
    Not lightweight or easy to move.
    But quite high quality.
    Politics is the antithesis of problem solving.
    1. calvin | Mar 12, 2009 12:49am | #7
      Marbelite, a cultured marble company available to us here in NW Oh. started a line of a couple shower bases/side walls that were meant to "fill" the space formerly taken up by a tub.  If available in your area, check them out.  I don't know if they are a national/regional company.A Great Place for Information, Comraderie, and a Sucker Punch.
      http://www.quittintime.com/
      1. calvin | Mar 12, 2009 01:03am | #8
        Hey, I loved your movie-what was it called-Full Montee?  Not my cup of tea but well done.
        I looked at Marbelite's website and they don't show the tub swap option I mentioned.  However, just got off the phone with my supplier and Marbelite does in fact offer this product.  Give them a call (see site  for phone number).  Novi, Mi.A Great Place for Information, Comraderie, and a Sucker Punch.
          JeffBuck | Mar 12, 2009 01:06am | #9
          it was a great movie.
          if you were more secure in yer manhood you would have laughed at the ending too!
          You kids are too uptight these days ...
          Jeff    Buck Construction
           Artistry In Carpentry
               Pittsburgh Pa
          1. calvin | Mar 12, 2009 02:01am | #10
            Ha ha ha.
            If you were more secure in your intuition you'd have known that I probably didn't even see it.
            Don't believe everything you read here, remember?A Great Place for Information, Comraderie, and a Sucker Punch.
          2. montee | Mar 12, 2009 02:23am | #11
            thanks all for your input. you gave me other options which is what i need. let you all know how i make out. if anyone knows of suppliers in mid-hudson, ny or tri-state area that would help.
            thanks again
            the full montee
            JeffBuck | Mar 12, 2009 06:58am | #17
            I knew you'd be insecure enough to miss a great movie.
            btw ... it is a great movie.
            all time classic.
                 Pittsburgh Pa
  4. YesMaam27577 | Mar 12, 2009 12:45am | #6
    In addition to the suggestion for Laurel Marble and tile, I'll suggest that you try to find a Wedi dealer/distributor in your area.
    Wedi shower bases are made for ceramic tile to be put over them. They are lightweight and easy to work with. And you can also get Wedi wall panels that go up the walls for more tile.
    I recently did a 3' X 4' shower with Wedi. Base, curb, wall panels, seam tape, drain, and urethane sealant -- total bill was about $700 (not including the tile).
    And as others have suggested, Kerdi, with a foam preslope is also a great idea.
  5. davidmeiland | Mar 12, 2009 02:27am | #12
    A 30 x 48 is smaller than code requirements, at least here. 32 and up....
  6. Pelipeth | Mar 12, 2009 03:10am | #13
    Swanstone 32x48 in agrigate about $450.00, best prefab bases on the market IMO. They also make a 32x60 for that tub replacement left or right hand waste. swanstone.com
    Set the base in structolite (something like plaster of paris) and your good to go. Any good plumbing supply house will carry swanstone, but you maybe stuck with center drain. You might also try Fiat bases if you really can't get a 32" base in. Swanstone - 800-325-7008.
    Edited 3/11/2009 8:17 pm ET by Pelipeth
    1. montee | Mar 12, 2009 04:48am | #16
      Thanks guys. Will have to figure a way to fit in the 32inch base.
      Mike
  7. andybuildz | Mar 12, 2009 04:04pm | #18
    By the time you find one you could just do a mud job : )
    Why do I keep...http://www.youtube.com/watch?v=n7ZkQC0riwc
    http://www.ramdass.org
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
