Shower ceiling of troweled thin-set?
lumbermonkey | Posted in Construction Techniques on March 22, 2009 10:15am
Is this possible? I want to trowel modified white thin-set over an existing tile ceiling in a small shower stall. Tile is sound. I’m thinking the thin-set might crack when spread out?
I want to end up with a white, waterproof ceiling that will take a scrubbing. Dura-bond and gloss paint? Plaster?
    Dinosaur | Mar 22, 2009 11:07pm | #1
    I'm thinking thinset won't stick very well to the glazed side of tile; and it doesn't make a very good finish material. That's not what it's designed to do.
    If you want a white, waterproof ceiling that will take a scrubbing, why don't you just put up white tile? (I am assuming the tile that's up there now isn't white and you want to improve light reflectivity in the shower stall.)
    Dinosaur
    foolish men call Justice....
  2. splintergroupie | Mar 23, 2009 03:03am | #2
    Call a bathtub and appliance refinishing outfit like Miracle Method or similar. They refinish tile, too, no muss, no fuss. You won't be able to clean it with a Brillo pad, but it's a pretty durable surface. I've had it done on sinks and it held up well.
    http://www.miraclemethod.com/ceramic-tile-refinishing.htm
      lumbermonkey | Mar 23, 2009 03:26am | #3
      Has anybody tried glazes over or mixed into plaster? Or maybe water or oil base poly over plaster?
      I'm going to skim a scrap of drywall with thin-set, see how it holds up with some bending. Maybe do another sample of thin-set mixed with gloss water-based poly. Definitely in the mood to try some weird science on this one.
  3. jimAKAblue | Mar 23, 2009 04:52am | #4
    I've tiled tile over tile but never on the ceiling. When I did he tile over tile, we painted the surface of the existing tile with a product that created a better adhesion. I can't remember what that was but it was some form of latex primer.
  4. andybuildz | Mar 23, 2009 07:13am | #5
    Dinosaur and I were just discussing Self leveling compounds which brings this thought into my lil ol head....you may wanna try buying some leveling compound...not self leveling though and do a few test tiles with it. I think that stuff adheres to "almost" anything REALLY really well...and then go over that with whatever you want.
    Henry's/Customs makes a great leveling compound in a small box or in bags. Dries pretty fast too.
    http://contractorservices.homedepot.com/StoreProducts/ProductInfo.aspx?cid=850812&pid=d7693e10-8106-4608-b0c9-68755057db63
    specs: http://www.custombuildingproducts.com/docs/tech_bulletins/Speedfinish%2010%20Part%20Spec%2012-08.pdf?user=arc&lang=en
    http://www.ramdass.org
    Jeff_Clarke | Mar 23, 2009 07:15am | #6
    "I want to end up with a white, waterproof ceiling that will take a scrubbing."
    Corian shower liner panels.
    http://www2.dupont.com/Surfaces/en_US/products/bath_sinks/tub_and_showers.html
  6. YesMaam27577 | Mar 23, 2009 05:06pm | #7
    >>"I want to end up with a white, waterproof ceiling that will take a scrubbing. "
    Sounds like drywall, maybe a skimcoat, but certainly a good quality paint job. Anything more is luxury.
    Politics is the antithesis of problem solving.
  7. User avater
    Sphere | Mar 23, 2009 06:24pm | #8
    Put a fiberglass tub up, upside down.
