Shower Curb- Attachment
sawdust_steve | Posted in Construction Techniques on December 15, 2016 08:39am
Okay we installed a new shower and the built up curb came out rather well. The tile setter installed lath over the waterproof membrane. the lath was mudded and then a marble saddle was used to cap off the top of the curb and the vertical sides were tiled. It’s all well and good for a while except the marble curb top has come adrift. It came off in one piece and it looks like it was attached to the curb with thinset- seemed like pretty good coverage so I’m not sure why the thinset would let go.
So my question is: should I try to re-attach the marble with another layer of thinset (seems like this wouldn’t be a great idea if it let go once before) or can I use a polyurethane glue such as a locktite PL type? Seems to me the poly would be the better way to go…
  1. calvin | Dec 15, 2016 11:03am | #1
    Steve
    First I'd call back the tile guy.
    if he didn't show, I have reset loose tile with PL Premiun and had it last.  Be sure to tip the saddle in slightly, and make sure the expensive door fits as before.
    user-2409187 | Dec 16, 2016 08:45am | #2
    Marble-compatible thinset
    Avoid the use of an adhesive. To avoid future cracking and/or delamination, the entire piece should lie on a bed of thinset. Re-do the work with a marble-compatible thinset. You want something that won't, over time, allow moisture to get beneath the cap. You'll be paying $30 or more for a sack of thinset of which you will use a few cups full. If your contractor is as good as his/her word, he/she will gladly redo this work at no expense to you. I will do this even 5 yrears after installation! It reaps huge PR benefits. Good luck.
