Are the escutcheons of shower fixtures supposed to be sealed off from water? Is there a way to seal them without it showing?
Janet
Janet
To prevent moisture buildup and improve performance, install a continuous air barrier—such as drywall or specialized membranes—under tongue-and-groove boards or other interior wall paneling.
Yes, partially. Depends on what type you have. For instance, I just installed a Delta shower valve that comes with a sealing ring that leaves out about an inch at the bottom so any water that gets in could drain off. Since I installed 12" tiles, I was able to position the valve so I would not need silicone to cover the area where the seal goes over joints.
I also installed a Kohler connector for a shower hose, which required a combination on silicone and an O-ring.
Sealing anything in the shower can be tricky if you do anything other than standard installations. For instance, if you install jets in the wall, it is a good idea to make sure the water stream doesn't hit a valve on the other side of the shower.
This is what I do no matter the year of the fixtures. Remove the escutchion, apply a "dam" bead of caulk behind where the esc. will cover. Leave the dam open on the bottom (run caulk 345 deg.)
Replace the esc. and run a good grade of bath/kitchen (non silicone) caulk around the plate, leaving an opening at the bottom. Wipe most of this off with a damp rag, effectively sealing the joint between the esc. and the wall surface.
http://www.quittintime.com/
