shower floor tile size?
tufenhundel | Posted in Construction Techniques on May 20, 2006 07:47am
I was told by a tile guy that the largest tile I could use on the floor of my shower is 3×3. I have a (roughly) 4×5′ shower and I need tile for the floor. Could I go with 6×6 and still accommodate the slope for drainage?
    LEMONJELLO | May 20, 2006 07:56am | #1
    smaller tile size on the shower floor lessens the diagonal points and low spots that occur when putting flat tile on pitched floor ( it pitches from the perimeter to the drain so it esentially a really low, wide bowl). Catching the bottom of you foot can be slice /rip stubb your foot, usually not pleasant to step on either. Your'e going to have high & low spots but the smaller the tile the smoother it will end up.
    Fairly common to use a more textured and smaller tile on the floor though. Ask him. He'll tell you why.
    Judo Chop!
    Edited 5/20/2006 12:58 am by LEMONJELLO
    Edited 5/20/2006 12:59 am by LEMONJELLO
      JeffBuck | May 20, 2006 08:04am | #2
      that ... and the grout lines keep ya from slipping.
      Jeff    Buck Construction
       Artistry In Carpentry
           Pittsburgh Pa
  2. JHOLE | May 20, 2006 01:53pm | #3
    I have 4X4 and it turned out just fine.
    However, I knew I was making things hard so the prep work was done with that in mind.
    My shower is 5 X 6.
    Remodeling Contractor just on the other side of the Glass City
Picture-Perfect Pergola
