Is there some type of “rubbing” compound that will clean the mineral deposits off the shower glass?
Thanks.
Thanks.
Check out the lineup for the 2024 Building Science Symposium featuring experts like Steve Baczek, Dr. Joe Lstiburek, and more.
i use clr brand cleaner. soak it down good and hit it with fine steel wool usally works well for me. clr stands for calcium,lime,rust remover get it about anywhere larry
Vinegar is a weak acid that will have a cutting effect on calcium water residues.
Much of what is deposited on shower glass is a combination of mostly soap and body oil residues and is well handled by frequent cleansing.
Ajax, and "Kaboom" have become my favorite cleansers...give'em a try!
..............Iron Helix
Look carefully at your "mineral deposits" to make sure that's what you are seeing. Shower glass can become etched and nothing I know of will fix that, short of new glass.
Mike Hennessy
Pittsburgh, PA
Another thing to try is one of the "after shower" sprays. (I favor Arm&Hammer brand because it doesn't contain bleach.) They don't immediately clear up the crud, but will slowly dissolve it, and prevent more from forming.
Thanks so much for the input. I try a few and check back.
