I am installing a shower stall on the second floor of my 1889 “balloon” cape. So the ceiling is pitched at about a 45 degree angle leaving no level spot for a light fixture. Is it better to install the fixture on the angled ceiling, or one of the walls? Does it matter? Also, in this instance (I.E. lot’s of moisture) is there a “special” kind of box and or fixture necessary?
While no home can be completely fireproof, implementing these fire-resistant details can increase resilience.
scott.. frame an upside down dormer on the angle and install a fan/light in it on the flat bottom..
*Mike,Great idea, but the ceiling height is too low (about 7'6"). it is either going to be on the angle or on the wall. Or, I guess, not at all.I'm only installing a light. I've got a bigger fan than I need in the bathroom itself which is only about 75 sq. feet.
*there are shower lights designed for wet area applications.... see if you can get a surface mount one and make sure you seal the back so you don't let wet moist air into the framing....
*there are recessed lights for wet area applications as well.brian
*That's what I was hoping to hear.
*Make sure the light is GFI protected.
