shower pan acrylic or fiberglass
bob55 | Posted in General Discussion on June 11, 2009 07:54am
i need a shower pan for a new bathroom  pan size 60″ wide 36″ deep. The walls are  on 3 1/2 sides . Question – an acrylic base is approx $600 and the fiberglass base is
approx $220. What are the differences & is it worth the price difference? Also what is the proper way to install the pan? thanks in advance.
has anyone heard/used Dreamline shower pans any good?
Edited 6/11/2009 5:10 pm ET by bob55
  1. cic317 | Jun 11, 2009 08:36pm | #1
    Go Acrylic, has a better factory finish won't stain & look like hell in a few years, Have the pan set in structo lite, or any light weight concrete mix to give it a solid base.
    Good Luck
    1. tashler | Jun 12, 2009 02:44am | #2
      How about acrylic compared to Swanstone?Glenn
      1. cic317 | Jun 12, 2009 03:05am | #3
        no experience w/ Swanstone bases, they look good, have had good results w/ their vanity tops
  2. Pelipeth | Jun 12, 2009 12:49pm | #4
    Go with Swanstone, but I feel you'll only get it 32 wide (deep). Acrylic to me just looks CHEAP. Chip the surface and your in deep do do.
      BillHartmann | Jun 12, 2009 03:12pm | #5
      "Chip the surface and your in deep do do."And what happens if you chip the surface of an acrylic, as it is uniform material?.
      1. Pelipeth | Jun 12, 2009 11:16pm | #6
        Are we talking acrylic as in GlacierBay's HD product?
          BillHartmann | Jun 12, 2009 11:37pm | #7
          I have no idea of what that is.But all of the acrylics that I have seen are monolith molded materials.Where as FG are a gel coat over FG & resin. And those can wear to show the base material and also chip..
          1. Pelipeth | Jun 13, 2009 12:21am | #8
            There is an excellent chance, I'm confused on the materials. In either case alot of the "materials" are just too shiny for my taste, it is plastic and looks it. Swanstone's products you can cut, drill, sand and it still has pretty much the same finish. I feel the quality is good enough for the pan to go with tile work.
            My only experience working with acrylic types was a sink top that was "captured" on both sides by walls. It had to be belt sanded in to fit and even with a belt sander the material still chipped. Refused to use it ever since.
  3. retiree | Jun 13, 2009 05:42am | #9
    Bob, I just priced a Kohler base to replace a tub.  It was 30 X60 and was also available in 33 X 60.  Both are in cast iron which will stand up alot better.  The quote was $467 and would be shipped to the store in three days.  Weight is 193 LBS.  You can find in on the web at Koehler.com.
    Edited 6/13/2009 12:12 am ET by retiree
Drafting the 2027 IRC
  • The New Old Colonial
