shower pan drain.
brownbagg | Posted in Construction Techniques on January 22, 2005 05:21am
shower pan drain. does the drain grill go above the tile or below the tile
  1. GB2 | Jan 22, 2005 05:54am | #1
    I recently finished a shower built from scratch. Reinforced floor, leveler,then slope to drain, LINER, durarock or hardy, fill seems, set drain so  grill will end up slightly, (.075" to flush) lower than the ceramic tile. Before I set the drain body in, I fill any gaps between the floor,drain body and durarock.
    Let me know if this is confusing or not what you're looking for.
    GB2
  2. Sasquatch | Jan 22, 2005 06:31am | #2
    If I understand the question, my answer is the circular metal part is about 1/16" - 1/8" below the surface of the tile.
    You want the water to be able to flow into the drain without obstruction.
