I’d like to put a tub into what is now a tiled shower on a concrete slab.
Since I don’t believe the drain in the tub is near where the drain in the slab is located I presume I’ll need to do some concrete work to connect the two. Having never done anything like this before, I’d appreciate any tips/suggestions/pitfalls to watch for.
TIA
Thon
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
Got to move the whole trap. Trap is a different
size for a tub. Trap attaches differently to a tub.
Need a well underneath. Got to jackhammer mucho slab.
Hope the vent is close enough. Pitfalls are many.
Not the best first-time amateur project. Need to remove
a good 3 foot chunk of slab.
Put a 55 gal drum in the shower and take a vertical bath.
Aiii carumba! But thanks. I've done plenty of building--and a fair amount of plumbing--and don't consider myself an amateur, just nothing like this. Could you elaborate on that 3 foot 'well'?
Thanks.
Thon
The well itself need only be big enough so you can
attach the tailpiece of the tub drain. The drain
with overflow tube sticks down about 6 inches from
the bottom of the tub. Add another maybe 8 inches
for the trap. If I need a hole underneath anyway,
I'd probably not bury the trap in concrete and leave
it accessible in the well. Obviously, the well must
be accessible from the drain end of the tub when you
remove an access panel. Otherwise, no way to connect
the drain after the tub is set.
Tub is 5 feet long. Shower is maybe 3 feet square.
Assuming you add a foot to each end, the tub drain is
about 2.5 feet from the current shower drain. Hence,
you need about a 1 by 1 by 3 foot chunk of slab removed.
If its covered by the tub, why fill it up again? Leave
the joint with the original drain visible. Now, hope that
the existing drain is not too close to the slab surface.
If so, you'll not have enough clearance for the tub tailpiece.
If its real deep, you'll have to trench deeper. The outlet
of the trap must be at the same depth as the drain. Otherwise
you have venting problems. So, all together you're looking at
a well about 1 by 3 feet and from 1 to 3 feet deep, depending
on how deep the drain line sits.
Hope the existing shower
has a vent in the right place. I think it has to be within
6 feet of the tub drain for a wet vent. You'll have to check
on that. If you can add your own vent, no problem. But,
need to tie at least 6 inches higher than the highest fixture
on that stack, which means somewhere on the second floor or
go all the way to the roof. I don't think you're allowed to use
one of those Studer vent things on a tub.
Also, hope you don't have drainage
issues or you might need a sump pump in there as well.
The tub drain being probably the lowest fixture in your
system, the tub will fill with you-know-what if there's
ever a blockage in the main.
Have fun.
EXACTLY what I needed! Many thanks for your time and assistance.
Thon
