Hi,
Well, I tried to salvage an old shower faucet so i wouldn’t have to change it out but after revamping the valves the diverter just just wouldn’t fully function so now I have to replace. My question is do they still make valve assemblies that you can change out useing the old union connections? I hope they do it’ll make the job much easier.
Mike
![](https://images.finehomebuilding.com/app/uploads/2024/09/05115529/012326-Know-the-Code-Feature-thumb-16x9.jpg)
There is no generic 2-ft. rule. Use the code tables to dial in joist spans and overhangs based on accurate engineering.
yes they do but dont meet code if that is a concern the problem you may run up aginst is the male ,female may not match up to create a water tight seal you will have to use the union supplied on new valve
