shower window
Sardog | Posted in General Discussion on August 16, 2008 09:45am
Hi all
I have an odd question.
How does one handle the problem of a window in a large walk-in shower?
Is there some trick to this or a special window?
What keeps the window from getting soaked all the time.
    PeterJ | Aug 16, 2008 11:00pm | #1
    Might try a search for shower window or some such, been discussed at length. I've done it with fixed glass, both vinyl frame and glass only. Don't think I'd want an opening window where it would see much splash.
  2. ChicagoMike | Aug 16, 2008 11:36pm | #2
    You could use vinyl. I use fiberglass non venting for a low window or an awning window for 4.5 feet or higher. I use Marvin Infinity.
    "It is what it is."
    1. Bob_B | Aug 17, 2008 06:56am | #3
      this poor dead horse was beat about a month or two ago so if you look thru the post you should find it. I have one in my rental place, glass block with an old aluminum window and no issues.  When I re-did the bath I cut the surround for the window and trimmed it out with PVC mouldings.  I used SS trim screws and loctite adhesive to put the trim up along with some serious calking. I check it a lot and ask the tenant to as well. If I was to do it again, I'd go with an all vinyl window, flash/rubber membrane it like it was on the outside and the same trim treatment. Just my 2 cents.
      BB
      1. Sardog | Aug 17, 2008 02:51pm | #5
        I did a search and came up with some of it, not the whole thread.
        I'll look again.
      2. ChicagoMike | Aug 17, 2008 06:19pm | #6
        Yeah, I remember, I'm not the OP, I just responded.
        "It is what it is."
    jocobe | Aug 17, 2008 02:23pm | #4
    It should be tempered glass!
Picture-Perfect Pergola
