Shutter attachment ?
dreuxgrad62 | Posted in Construction Techniques on December 10, 2010 02:47am
Have had siding replaced with Hardie over original 1/2″ foam(NO BACKER BOARD).
Suggestions for attaching metal shutter clips appreciated.
Thanks, Ed
  1. calvin | Dec 10, 2010 03:44pm | #1
    Metal clips?
    Are these for the snap on plastic shutters?
    Have you contacted hardi?  I would think a plastic anchor would work, perhaps the ones with the wings that flip out-sized for the thickness of siding at the point of fastening.
    1. dreuxgrad62 | Dec 11, 2010 11:02am | #2
      They are for plastic shutters and awaiting an answer from hardie.
      Thinking that the wings would not open in the foam board.
      Obviously next time, I'd replace the foam with ply to hold the mounting screws
      Thanks, Ed
      1. DanH | Dec 11, 2010 11:14am | #3
        Heck, the Hardie alone should hold clips for plastic shutters just fine, if you use the right screw.  A large, stubby sheet-metal screw should do the job.
