Side Vented On Demand Hot Water Heater
tpmcnichol | Posted in Energy, Heating & Insulation on March 15, 2012 07:11am
Question:  Does anyone know if or a make of a gas on-demand hot water heater than can be mounted on the exterior of a house and doesn’t have to be vented up?   I’ve seen side vent fireplaces…but not hot water heaters.
Need: Relocate a hot water heater to an exterior location
Solution:  Install on the side of a 2-story house, first floor, behind a brick chimney.  Chimney blocks view from street.
Problem: 4″ clearance to structure next door
Problem: There’s a series of windows directly above the target installation area….so venting up the side of the house won’t work.
ted
  1. DanH | Mar 15, 2012 08:25pm | #1
    Pretty sure I've seen "high
    Pretty sure I've seen "high efficiency" units that vented like a condensing furnace.  But no way would it be legal to vent into a 4" space.
  2. therosswelsh | Mar 15, 2012 08:50pm | #2
    exterior mounted on-demand water heater
    Noritz has at least one exterior mounted model. I installed one on a guest house in Amador county California this last summer that included a freeze protection kit. It is basically cold water and propane in and hot water out. It exausts right at the unit. Can you give more of a description on the 4" clearance problem
    Ross
  3. rdesigns | Mar 16, 2012 09:40am | #3
    Did you mean 4' instead of 4"?
    If so, there is likely a model that can be installed within the clearances to windows.
    You will have to check the manufacturer's clearnance requirements, but most direct-vent gas appliances over 50k BTU can have the vent termination only 12" from openings into the building. (International Fuel Gas Code, section 503.8, item 3)
