I was always taught to space the long edges of your shingles, but lately I see alot of sidewall shingle butted tight together. Did I miss some new revelation?
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
depends on the shingle and the use and the locality..
roofs.. definitely space
sidewall.. WC...EXTRA, tight but not fitted
WC , (R&R ) tight and fitted
sidewall RC (R&R) tight and fitted
but.. if you are going to have a very wet time and they will get soaked thru and not dry out.. they are going to swell .. a lot.. and you can get buckling.. happens a lot on north sides
i think some get carried away and start shaving R&R's .. i personally like to lay an R&R just as it comes out of the box... the slight imperfections give just enough space to stay out of trouble
Thanks Mike.
I'm in the San Francisco area, so we do have lots of rain. Sorry, but I'm not familiar with R&R RC and WC what do those mean?
Thanks!
wc.. white cedar.. ( two most common are EXTRA , & CLEAR )
R&R.. rebutted & resquared
RC... red cedar ( #1 , #2 )
any of them can also be R&R.. usually R&R comes in boxes..
non-R&R come in bundlesMike Smith Rhode Island : Design / Build / Repair / Restore
Oops..I knew that! Thanks!
So I'm thinking in my area with #1 Red Cedar a nail space as I have always done is smart?
mebbe..
if your RC is not R&R.. they are usually just enough out of square so i let them touch each other where they want to..
it will automatically gap most of the shingle.. ie: the 18" shingle might be touching for one inch.. the rest will have a slight gap.. especially if you lay your courses on a course stick and don't let them stair-stepMike Smith Rhode Island : Design / Build / Repair / Restore
With #1 or #2 WRC 16" bundled shingles there will be enough personality to them so that the vertical edges will not be parallel anyway... so is the nail space the minimum or the maximum?! I always stick a straight piece of 1x4 across the wall and stack the shingles on it, so that the butt lines are nice and straight, and space the shingles an average of about 3/16" apart. If you are buying and installing shingles that are soaking wet you could go with less.
What are you fastening them with?
I usually do the 1x4 strip as well and space about 1/8" maybe on the long edges. I normally fasten with EG box shingle nails although I think next job I will step up to SS.
Does EG mean electro-galv or does it mean something else? I would not use electro-galv anything for fastening cedar... you will get bleeding that shows. I use 7/16" x 1-1/4" SS Senco staples for my shingling, and Mike can recommend a sidewall nail gun and HDG or SS nails to match... was it a Max? For what it's worth, a box of 6000 SS staples costs me about $75, and I would figure on about $20 per square for 'em if you go that route.
I haven't done shingling for quite some time and did back then use hot dip galv, but on this job I think I'm going to go with SS. Thanks!
dave.. have you got an answer to that screed question ?
http://forums.taunton.com/tp-breaktime/messages?msg=58045.27Mike Smith Rhode Island : Design / Build / Repair / Restore
