I want to reside my house with Vinyl. Its currently plywood with 1″ battens every 16″. Any problem with filling between the battens with 1″ foam and going over with the vinyl
Dave
In older homes like these, the main remodeling goal is often a more welcoming, more social, and more functional kitchen.
use 3/4 foam...
you'll like the results better...
make sur yur battens are firmly anckored..
WOW!!! What a Ride!
I would strip off the battens and if you want run continous foam.
A better insulation, B better water protections, and C it is a lot lot easier.
