Siding Nails vs. Finish Nails
Jeff_Clarke | Posted in Construction Techniques on December 28, 2004 08:35am
We’re nailing CVG WRC pre-primed/painted drop siding (sometimes referred to as German novelty siding) to existing (old) studs and 1/2″ sheathing.
An option for stainless annular ring finish nails has been discussed – what do you think of that idea vs. standard coil annular ring siding nails – the head here is the difference.
The reason is to minimize hole filling, which won’t be done until spring.
Thanks in advance for your thoughts –
Jeff Clarke
Edited 12/28/2004 12:46 am ET by Jeff
    NickNukeEm | Dec 28, 2004 02:51pm | #1
    My house was sided with WRC clapboards using galv. finish nails.  The heads are too small to prevent any movement of the cedar, consequently we had to replace the entire south side siding, they had curled so badly.  We used SS ring-shank siding nails.  Novelty siding might be different, but I don't think I'd take the chance, we're not talking furniture here.
    JDRHI | Dec 28, 2004 07:50pm | #2
    Nicks right....finish nails aren`t going to hold up well over time.
    J. D. Reynolds
    Home Improvements
    "DO IT RIGHT, DO IT ONCE"
  3. byrnesie | Dec 28, 2004 08:34pm | #3
    I agree that stainleel steel ring siding nails are best. A common mistake though, is to nail the clapboards or siding boards through each other, pinning them all together. This won't allow for the boards to expand and contract with out cracking along threir length. Face nail, but make sure the nail goes slightly above the board under it allowing it to slip when expanding and contracting.
      Jeff_Clarke | Dec 29, 2004 05:34am | #4
      Thanks to all ... seems consistent with search results here too.  It was a suggestion from the builder ... I just wasn't completely sure.
      SS ring-shank coil siding nails it is.
      TJC
  4. reinvent | Dec 30, 2004 03:03am | #5
    If you havent put up the siding yet consider puting up 'homeslicker' first. Keeps moisture from building up behind the claps, helps the paint last longer. http://www.benjaminobdyke.com
      Jeff_Clarke | Dec 30, 2004 06:35am | #6
      Thanks - I haven't seen that product yet, although we are designing some rainscreen (furred) exterior walls here (NJ).
      TJC
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
