Siding Transition Detail
wivell | Posted in Construction Techniques on December 9, 2002 08:38am
I’m working on an addition which has a brick ledge about 16″ above grade.  The framing is set 4″ back from the brick ledge – did it this way in case I ever brick the whole thing.
I’m going to install fibercement or vinyl for now.  Looking for some guidance on the proper flashing/transition detail.  Should I fur out the walls so the siding is flush with the brick veneer face or just install a “cap flashing” over the brick.
Vinyl or fibercement?  I really like the looks of the fibercement but hate painting….
Scott
  1. xMikeSmith | Dec 10, 2002 01:46am | #1
    here's one we did that had a problem similar to your brick ledge.. this is Certainteed Fibercement with GP Primetrim watertable & trim
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
    1. 69firebird | Dec 10, 2002 03:30am | #2
      Workmanship looks great but where is the flashing?
      1. xMikeSmith | Dec 10, 2002 06:03am | #3
        you saw step 1 and step 15... flashing was step two.. ice & water and a custom white alum. break flashMike Smith   Rhode Island : Design / Build / Repair / Restore
      2. xMikeSmith | Dec 10, 2002 06:09am | #4
        here's some of it.. the white break flash.. the ice& water and the kick strip for the bottom courseMike Smith   Rhode Island : Design / Build / Repair / Restore
