Silicone Caulk – Subzero application??
Hypotenuse | Posted in Construction Techniques on January 11, 2006 12:54pm
What are the temperature-related problems with using silicone caulk in freezing weather?
If a large multi-part window install butts aluminum and composite up to brick, will the silicone caulk bond in the cold?
Should I wait until 40+ degree weather before doing the work?
  1. macmillan | Jan 11, 2006 02:04am | #1
    Your caulking tube should have an 800 number on it, I have often gotten valuable tech support for just such questions. Geocel, and PL polyurethane caulk may work for this if the tubes are kept warm before use.
    Sphere | Jan 11, 2006 03:23am | #2
    Geocel is good to -40F OR -40C funny how both scales meet there huh?
    1. rasconc | Jan 11, 2006 06:23am | #3
      First time I that ever occurred to me I was sitting right seat in a small jet as co-pilot.  Any time I hear someone say 40 below I ask F or C.  When they say one or the other I say "whatever".
      Lexel will go pretty low IIRC.
      Edited 1/10/2006 10:25 pm ET by rasconc
      1. RedfordHenry | Jan 11, 2006 06:36am | #4
        Don't know the answer to your question but the label on lexel (which I believe is superior to silicone anyway) indicates you can use down to 0 degrees F.  For a couple of bucks more per tube, why take a chance with silicone?
  3. bigfootnampa | Jan 11, 2006 08:16am | #5
    Get some Paint Flex silicone.  Lowe's has it here.  The label specifically states that it is good to (way WAY below zero).  I have used it for winter caulking too.  Tricky stuff to get a nice finish on but very  durable and will withstand weather conditions that I'm sure never gonna go out to caulk in.  Supposed to be paintable too and I prefer it to the sister product (Weather-Flex) for that reason.
Mortar for Old Masonry
