sill seal
Sphere | Posted in Construction Techniques on December 31, 2003 05:56am
so, if I had to use new pt for a sill plate, and termite shield, could I use 1/4 ” tile backer on the block? I know I will have to have a pestcontrol applicater SOON..for now I want / need to yank the band and sill..thinking like this..alum. flashing on top of block, 1/4 cementicious backer board, no sill seal (un heated crawl area) then 2×8 pt sill plate, rip the 2x band to 1/4 less (2×8) in this case…and being as this is the side w/out the joistends, parallel to the joist run insert the new band?
When and if I need to do the bearing side, same thing but let the joists sit on the now 1/4 ” higher sill and hope they squash a bit?.
Is a double band now standard? It makes sense to me , but thats me.
  1. joeh | Dec 31, 2003 07:36am | #1
    My experience with concrete & aluminum & ground level exposure is aluminum turns to white slimey stuff and disappears after a few years.
    Can't guess what the new PT does in contact with aluminum, I guess that's why you're putting the backer board in there?
    Copper might be the best choice,  I don't think aluminum flashing will last long.
    Joe H
    1. DaveRicheson | Dec 31, 2003 04:04pm | #2
      Years ago, on raised foundations, the only place termite shield was used was at the poured stoop or steps to the entry doors. This was before my time, but I have seen a lot of them. It was also b/f pt lumber was used for masonary contact.
      The reason I mention the placement is that most of them were of flashing lead or a heavey galvanized steel. They were placed beneath the mud sill at the step or stoop /porch junction, and the concrete poured over  them. In the case of a poured porch with foundation wall the fill was generally soil, soil there was an avenue for termites to secretly get to the untreated mud sills.
      I am wondering if rolled lead flashing would work with these new PT lumber?
      Dave
    2. andybuildz | Dec 31, 2003 04:26pm | #3
      I used a newish termite shield...Way easier to use and its copper but a seriously thin layer of copper glued to a sort of water proof fabric/paper.
      The sill sealer I used was a roll of foam rather than the standard fiberglass sealer...Makes sense as far as moisture goes.
      One other thing I figured out doing my own crib was to go into the crawl space and look where I saw light coming through and squirted in Touch N Foam. MAkes for a nice tight seal.
      Be warm
                  andy
      My life is my practice!
      1. JEDDAN | Dec 31, 2003 05:10pm | #4
        There is a new product out there that is a flashing and sill seal in one, can't remember the name. In my neck of the woods ( central Oregon coast ) anything that is on the shell of the house is stainless steel no questions.Orca Builders
        Killer homes since 1988
