Silver Solder
| Posted in General Discussion on October 19, 2004 09:53am
On my bathroom remodel project the inspector is requiring silver solder on the under-slab copeer water pipes.  I’ve abandoned a few pipes where we moved showers and toilets.
Will MAPP gas heat the pipes enough to silver older, or do I need an acetylene torch?  Any tips?  Thanks
    Sphere | Oct 19, 2004 09:55pm | #1
    mapp will do it ok up to 3/4" pipe.
    1. brownbagg | Oct 19, 2004 10:30pm | #2
      mapp will work fine, so will propane, but you cannot have any joints under the slab. must be one piece.(code item) pipe also must be sleeve in concrete.
      1. Milligan101 | Oct 19, 2004 11:47pm | #3
        I don't have a choice in this case.  We moved walls where the toilet and shower plumbed from under the slab.  I think that's the reason the inspector is insisting on silver and not tin-antimony solder.
        My plan was to wrap after solder to keep the concrete and soil off the pipe and joint.
        1. CJD | Oct 20, 2004 12:21am | #4
          Have you considered PEX? It has good chemical resistance to concrete and is seamless.
