Hi, I am going to build a 2x6x10 partition wall in my detached garage to basically create a room… wall will be 22ft in length and attached to the front and rear exterior 2×6 framing.
my question is how to best secure the top and bottom plates… the flooring is osb and plywood on top of joists 16” o.c.
the wall will fall between joists so I am wondering if I need to add blocking or if it will be enough to just nail to the plywood/osb flooring?
as for ceiling, would blocking be needed here also? There is already strapping in place, should I cut the strapping so that my new wall matches height of the exterior walls without needing to cut the 10ft studs? I have attached pictures for clarity
thx
This is a non bearing wall. Unless you want extra insulation you could use 2x4. Nail the bottom plate to the floor with 1 16 nail on each side of the studs. Use a single top plate and leave 3/4" from the top of the wall to the strapping so there is no load on the wall. No need for blocking but nail through the top plate into the strapping to secure the wall. Hang the drywall on the ceiling before putting the wall up if you want. If it were me I'd use steel studs.
What brand of practice mat is that? Do you like it? Any downsides?
Grandson 10 y.o. starting to play. We’re 500 mi away so we see him only on visits. If he’s serious this might be a good present for over the winter.
Thanks.
Thanks Mikemahan… the 2x6 was for insulation purposes and I wanted plenty of wall cavity to also recess a flat screen tv… I actually just realized that the new wall will be on top of the plywood flooring whereas the existing walls were built before the flooring, so with 3/4 difference on flooring and 3/4 with the strapping, I should be perfect height match with the single plates and 10ft studs.
Calvin- that’s actually a birdieputt putting green, they have great putting greens of all different sizes but definitely not to be hit off of. It is a foam material with “hairiness” on the putting side. You can get them with different speeds and inserts to create breaks as well as bumper surrounds and shallow cups with flags. The one in my pic is not set up. I’m still deciding on hitting Mat since all of this is for a simulator… there are many different options.
Ran across a report on steel framing vs wood framing related to thermal performance
https://www.huduser.gov/publications/pdf/steelval_rpt.pdf
Bottom line is that wood studs perform better.
