Simpson Strong Wall retrofit
Scott_M | Posted in General Discussion on October 30, 2006 01:46am
I have a 2 story garage that was just framed. The plans call for a Simpson StrongWall Garage Portal SSW12X7 on each side of the door.
The strong wall panels were not put in during framing. I don’t know if this was an oversight, or a cost cutting measure.
Now that the building is up & sheathed, can the strong wall be retrofitted into the wall?
Scott
  1. rez | Nov 06, 2006 08:58pm | #1
    Greetings Scott,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    when in doubt add garlic
  2. Rockford | Nov 06, 2006 10:36pm | #2
    Scott,
    Cutting the existing framing to get the Simpson walls in are not the problem.  It's the anchoring that's the problem.  Those walls require two 7/8" SSTBs and two 5/8" anchor bolts.  In Los Angeles, the pour of the concrete around these particular bolts have to be witnessed by a deputy inspector.
    Good luck.
  3. JohnSprung | Nov 06, 2006 11:08pm | #3
    It can probably be done, but it's all in the details of the specific structure. It would require temporary support and a tad bit of lifting of some of the structure.  As Rockford said, anchoring will also be an issue.  It may be more cost effective to have your engineer design a different kind of fix.
    -- J.S.
    1. davidmeiland | Nov 06, 2006 11:37pm | #4
      It shouldn't be hard to find out whether or not all-thread set in epoxy will provide the necessary withdrawal strength. If it will, set the wall, drill the holes, and glue in the rods.
      1. Gimby | Nov 06, 2006 11:50pm | #5
        I used retrofit epoxy bolts for a Hardy Frame (two 1/18" bolts and one 3/4") and it was no problem here in San Diego. I did have to have a special inspection to verify hole depth and cleanliness.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Grand Rescue on the Coast
