What is the best method to match the sink profile when cutting the hole in the counter surface?
I have read the ‘Making a Solid-Surface Counter’ article in FHB#84 pg.40., but the article does not give enough detail in this area.
I plan on using a 1/2″ flush trim bottom bearing router bit for the cut. The problem I see is the sink has a continuos radius profile up to the rim, so if the bearing follows the radii the cut out will stand proud of the true sink edge.
Any ideas to have the opening match the sink?
Edited 5/8/2002 10:23:17 PM ET by TLIPA
there is a "bowl bit" made especially for this
Do you know who stocks that bit?
try woodworker.com
be careful....there are many bowl bits made, lots of them specific to the shape from a particular bowl manufacturer....that is, you buy bit A to match a Corian bowl....but it may not work well, or maybe hardly at all, with a bowl from another manufacturer, which needs bit B. Some bits cut flush, some leave a little overhang too.
Look for tooling suppliers links at the solid surface websites, the one for ISSFA and Solid Surface magasine.cabinetmaker/college instructor. Cape Breton, N.S
