SIPs in a wet climate
ibweavn | Posted in General Discussion on March 19, 2007 07:32am
Hi everyone,
I am planing to build a house in the next year. I want to have a very energy effiecient small house.(less than 1500 sf) I am wondering how do SIPs hold up in a very wet climate. I live on the coast of Northern Ca. We get a lot of rain. Some contractors I have talked to say they have heard of rot problems with SIPs, but they don’t have person experience. Any advice?
Thanks.
  1. jross | Mar 19, 2007 05:43pm | #1
    I’ve seen two details that will go a long way towards keeping the SIP skin material (usually OSB) in good shape.  One is to provide a ventilation space (one product I’ve seen is something called Home Slicker) between the siding and the sheathing.  The other is to back prime whatever siding material is used.
    jross -- FH Editorial
    http://www.sipbuilding.wordpress.com
  2. frenchy | Mar 19, 2007 06:16pm | #2
    ibweavn.
      MY SIPs sat exposed to the rain, snow, and everyother thing for 4 years before I finally got shingles over everything.. Solid as new.. SIP"s will decay if they sit in water just like any other OSB will..
     All a SIP is is two sheets of OSB seperated by a block of foam.. the foam is impervious to water but the OSB will rot.. Good SIPs use a waxed or sealed version of OSB to avoid water damage issues during construction.   Use normal building practices to ensure that the OSB is  off the ground and out out of constant touch with water.
     Contractors are in a way like little children, they are afraid of things they aren't familar with.  Once they build with SIP's it's a piece of cake and they too will fall in love with the process. May I suggest that you have your contractors contact me if they'd like some personal information. There are plenty of others who have successully built with SIPs and find it very much a do-it-yourself kind of project.. anything that is easy for a do-it-yourselfer to do should be a real breeze for a pro to do..
