Sizing a Footing
bozobozo | Posted in Construction Techniques on August 17, 2011 05:53am
Any advice on sizing footers for load bearing walls in a basement.  Building a new house and I want to design using walls instead of steel posts to support the first floor.  I plan on using 2×6 for these walls.
  1. calvin | Aug 17, 2011 09:06pm | #1
    boz
    footings are sized according to the load.
    If you made them the same as the perimeter footings...............................you'd probably be fine.
    But, surrounding those posts with a wall would do the same, lower the amount of concrete you'd need for footings.
    With a 2x6 wall, you'd have no problem covering the tilt of those posts.
    So, your cost difference, minus the labor, would be the difference in a beam or a continuous footing.
    And of course, when you pour the floor.  If no beam, then you'd have to pour and build the wall vs. post and beam.
