Skil Table question
Frandelhi | Posted in Tools for Home Building on September 13, 2005 02:42am
Before I buy the Ryobi (the with the 27 rip).  I was thinking if I need to do something or missed about my skil table saw.  Originally, the switch was the problem, it sort of gave way as brought about by on and off  thus I decided to replace with the ordinary one (replaced one as per advise of the people at HD).  Anyway, as I replaced it, it worked after a few wood a but suddenly stopped regardless of me having it directly plugged to the main switch.  I just can’t believe that it will not work suddenly because of switch replacement.  Is there a reset button that I should do for the motor or it is really out?  I don’t think motor is burn.
Thank you all for your response.
  1. rez | Sep 16, 2005 03:09am | #1
    Greetings F,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    sleeps till noon but before it's dark...
  2. FastEddie | Sep 16, 2005 03:53am | #2
    I bought a really cheap table saw at Lowes about 6 yrs ago ... cost $89 then.  The swich gave out after about 3-4 years, so I went to Radio Shack and bought a toggle switch rated for 120V 15A and drilled a hole in the front of the saw and wired to the new switch.  Works quite well.
    There is a small button on the front of the saw that is a circuit breaker.  It has only tripped about twice.  See if you can find a small button, about the size of a pencil eraser.  With the saw unplugged, push the button in.  If it stays in, then it's reset.  If it won't stay in, then I guess the CB is bad.
    If you think you need a new saw, look at the Ryobi at Home Depot.  It's a little less than $200, comes with a built in folding stand with wheels, and is surprisingly good for a Ryobi.
  3. USAnigel | Sep 19, 2005 06:47am | #3
    Also check the motor brushes.
Mortar for Old Masonry
