Skim Coat/ D-Mix as well
bluewhale | Posted in General Discussion on December 5, 2006 03:50am
Hey i tried the D- Mix and general skim coat  The d Mix is great i maybe didnt use enough pop as i should have but in general how do i make my skim coat water resistent?  If i take my finger and wet it i can get some of the coat to come off.  Now i dont plan on getting the wall wet but just in case i get a leak i dont want  the wall to sag.  If i use setting joint compund instead would that be a little bit more water resistant?
  1. sharpblade | Dec 05, 2006 07:08pm | #1
    Prime and paint.
  2. GreatWhiteNorthGuy | Dec 05, 2006 09:30pm | #2
    I think you should realize that it's more "like" a plaster rather than the rock-hard, cement-like finish of true plaster. However, once it's properly primed and painted you'll end up with a superior finish that doesn't require a curing period or special paints that resist lime burn.
    Cheers,
    Ken
    "They don't build 'em like they used to" And as my Dad always added... "Thank God!"
