I have a basement with cement block walls. I would like to give these walls a more finished appearance by skim coating them, to replace the block-and-mortar grid with a uniform but slightly textured surface. I live in a freeze-thaw climate. The block walls have already been painted with oil and/or latex paints. There is currently no moisture or dampness problem, and I am anxious not create one with this project. Should the new coating be able to “beathe” and allow air and moisture to pass normally? Can anyone suggest a product that would give me this result? Are there any special techniques I should use in preparing the old surface or applying the new material in this application? Many thanks in advance for your suggestions.
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
John,
I had a problem skim coating over some existing brick. Call US Gypsum - you can get their number at http://www.usg.com I think. They called back and gave recommendations on plaster, finish coat, and bonding agent.
*i have used the topcoat of eifs( dryvit ) type exterior stucco for this application. i goes on easily, is paintable if you decide to change colors later, and is durable.
*I have skimmed block with Durabond. It worked well and was done over painted block. Knocked off any hods/mortar and hit the mortar joints first. Then proceeded with skimming both horizontally then vertically, again with the Reg. Durabond. Final coated with easysand. This gave a smooth wall. Did another and did a knock down texture skipping the last coat. Best of luck.
*Unless you are after a plaster-smooth wall, I have had real good luck using Sure-Bond (a surface-bonding coating).In the past I have also used a top coat of Thoro-Seal thickened with a fine sand.Terry
I have a basement with cement block walls. I would like to give these walls a more finished appearance by skim coating them, to replace the block-and-mortar grid with a uniform but slightly textured surface. I live in a freeze-thaw climate. The block walls have already been painted with oil and/or latex paints. There is currently no moisture or dampness problem, and I am anxious not create one with this project. Should the new coating be able to "beathe" and allow air and moisture to pass normally? Can anyone suggest a product that would give me this result? Are there any special techniques I should use in preparing the old surface or applying the new material in this application? Many thanks in advance for your suggestions.
