Slaking grout
jyang949 | Posted in General Discussion on August 19, 2008 10:14am
Is it necessary to let grout slake in the mixing container? It would be easier to push the grout into crevices before it thickens, and allow more time to work. Wouldn’t the grout slake anyway, once it’s between the tiles?
I’m wondering if there’s a chemical or structural reason to slake before applying the grout.
Janet
  1. MisterT | Aug 20, 2008 01:13am | #1
    grout is a mixture of binders, pigments and solids to perform properly ALL the ingrediants must be "Wetted" by the water.
    some of the ingredients absorb the water slower than others, Slaking allows them to "catch up"so they can react appropriately.
    also the water will soak into any clumps and assure that they are mixed more homogeneously (hope that doesn't get the ###)
    "After the laws of Physics, everything else is opinion"
    -Neil deGrasse Tyson
    If Pasta and Antipasta meet is it the end of the Universe???
    1. Piffin | Aug 20, 2008 02:18am | #5
      "ALL the ingrediants must be "Wetted""LOL, sometimes the short version is best!'course the shortest version is just, "YES!"
      1. MisterT | Aug 20, 2008 03:04am | #10
        I'm not an "Institute of Colloid and surfactant science" graduate but I play one on TV....
        "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
  2. arcflash | Aug 20, 2008 01:47am | #2
    It may help with air bubbles too. If the directions on the bag tell you to slake, then you'd better do so. Mix it just a little bit wet if it gets too thick on you.
    1. Piffin | Aug 20, 2008 02:21am | #6
      be carefull with that "little bit wet"That can make it easier to work, but most failures come from too wet.
  3. Piffin | Aug 20, 2008 02:14am | #3
    The instructions say so, right?
    I've never been one for just plain going by the book either without understanding why...
    So you need to see the process on a microscopic scale.
    The goodness of cementious products like this is dependent on both a chemical reaction and a mechanical one.
    Essentially the primary ingredients are the parts of microscopic sea animals from long ago. They are shaped much like small suction cups.
    Then you need to remember how surface tension of water works. Spill a couple drops on a glass surface and see how it beads up? It takes a little mechanical action for it to spread out over the surface.
    That is what is going on with mixing, then slaking off, then mixing again - you are letting the surface tension of the water break down and fill the cups of the little old seashells so there is no air interfering with proper adhesion that will hold the powder together for a lifetime.
    If you work it too quick and you have failures such as shrinkage cracks or flaking.
      Sphere | Aug 20, 2008 02:16am | #4
      Little sea shells? Man, I want to wear YOUR glasses, mine suck. All I see is grit..LOLSpheramid Enterprises Architectural Woodworks
      1. Piffin | Aug 20, 2008 02:27am | #7
        You gotta learn to GROK it man!
          Sphere | Aug 20, 2008 03:01am | #9
          Ah Master, I am but a lowly weed hopper in your vast meadow of wisdom.Spheramid Enterprises Architectural Woodworks
          Sphere | Aug 20, 2008 03:09am | #11
          Hey, I just wetted my grout..I got a batch of SEA MONKEYS!
          Cool!Spheramid Enterprises Architectural Woodworks
          1. Piffin | Aug 20, 2008 03:30am | #13
            and I just about wetted my pants laughing at that
            Sphere | Aug 20, 2008 03:37am | #15
            Seriously, who else but you knew that grout was Sea Monkeys? Not too many folks I'll bet.Spheramid Enterprises Architectural Woodworks
          3. Piffin | Aug 20, 2008 03:42am | #16
            quit riding the monkeys now or somebodies grout will get stiff.
    2. ChicagoMike | Aug 20, 2008 03:28am | #12
      Your knowledge never ceases to amaze me.
      You're a real smart feller, feller smart. Say that fast, 10 times. LOL!!
      "It is what it is."
      1. Piffin | Aug 20, 2008 03:35am | #14
        Yah, Yeah, Yeah....all the wimins say the same thing too;)
  4. Pelipeth | Aug 20, 2008 02:53am | #8
    I always mix again after slaking time allotment. Directions say so.
    JeffBuck | Aug 20, 2008 04:02am | #17
    if U have to ask ...
    U obviously haven't laid enough tile.
    or have laid the tile U have laid ... ? ....
    not fast enough.
    'cause ... if U had laid enough ... or enough fast ...
    You'd not even question the slaking.
    the slake ... is a wonderful time.
    it's a time to chug a bottle of cold water ...
    a time to hit the portapotty ...
    a time to wander around the job site and annoy all the other trades who aren't forced to "slake off" on a hot summer day ...
    slaking is time to stretch the knees and clear the mind ...
    zen kinda stuff ...
    before getting back to the hard work of laying tile.
    slaking is a natures way of saying ...
    hey kid ... relax for a minute ... or 10 to 15.
    there's plenty of hard work to do ...
    no need to rush into it all at once.
    only reason I tile is to slake.
    take that away ....
    and it's too much like roofing!
    'cept .... lower. usually closer to the ground.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. Piffin | Aug 20, 2008 04:08am | #18
      One of your more beautiful posts - like watching a flower unfold in time lapse!
        JeffBuck | Aug 20, 2008 04:09am | #19
        well ....
        it was from the heart!
        Jeff    Buck Construction
             Pittsburgh Pa
        Heck | Aug 20, 2008 04:09am | #20
        Kinda like a really long haiku.
    2. MisterT | Aug 20, 2008 04:10am | #21
      I never thought of you as a slaker... a slacker, but not a slaker....
    3. arcflash | Aug 20, 2008 04:39am | #22
      Freakin' poetic!!!
      That seashell thing was a light bulb moment for me as well.
    4. Huntdoctor | Aug 20, 2008 04:42am | #23
      jeff,
      "Its to much like roofing?"
      You don't let your shingles slake? Maybe that's why it take me so ong to shingle a roof.
      Russell
      "Member of the Jewish Carpenters Union"
      Heck | Aug 20, 2008 05:20am | #25
      'To slake, or not to slake: That is the question.
      Whether 'tis nobler to suffer the shame and call backs from improper grouting,Or take the time to properly slake as per the directions.
      Edited 8/19/2008 10:21 pm by Heck
      Edited 8/19/2008 10:23 pm by Heck
      1. Piffin | Aug 20, 2008 05:50am | #26
        This thread is turning into a library! We have poetry, zen religion, history, chemistry, business, technical trades, romance....
          JeffBuck | Aug 20, 2008 06:09am | #27
          "We have poetry, zen religion, history, chemistry, business, technical trades, romance...."
          isn't that the list of what's been banned!
               Pittsburgh Pa
          1. Piffin | Aug 20, 2008 06:14am | #28
            "Forum creep" it must be!A version of mission creep or budget creep.All we need now is a singing librarian wearing purple to mix the grout
    6. Scott | Aug 20, 2008 07:54am | #29
      Wow... slake poetic artistry....Can you do a MC freestyle rap at the next BT fest? Sweet stuff....Scott.Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
      1. Piffin | Aug 20, 2008 02:16pm | #30
        Anybody know how to pronounce this word?Is it slack, soft A or slaeke hard A?and are there regional differences?
        1. MisterT | Aug 20, 2008 02:19pm | #31
          cut me some slake brotha
          take up the slake.
        2. calvin | Aug 20, 2008 02:48pm | #32
          Don't have a bag of grout to look at, but here in NW Oh I have always used the long A pronunciation.
          How is it spelled on the grout bag?
          slack
          slake?
          Don't know if grout succumbs to roberts rules of order or the marcus of canterbury's rules but "ake" is usually long A.A Great Place for Information, Comraderie, and a Sucker Punch.
          http://www.quittintime.com/
          1. Piffin | Aug 20, 2008 03:16pm | #33
            OK, I knew I had a carton of grout or two on the shelf over there, so I went to look and see how they spelled it.My grout was black BTW, so you can imagine how my keyboard and face looks now, having gotten residue on my fingertips while rotating the carton looking for the english version of the instructions....So after all that, and getting my eyeballs narrowed down to the fine print focus...The way they spell it is s-i-t as in "...allow the mix to sit for ten minutes..."LOL
            Sphere | Aug 20, 2008 03:21pm | #34
            Reminds me of a Thanksgiving dinner and ex-bil mentioned the taste of the green onions, but he called them "Scullions" , everyone at the table corrected him and said "It's SCALLIONS, you moron"
            This went on for awhile and finally he grabbed a dictionary and came back into the room and said, "Ok, lets see?"  'S...Sc...Ok HERE IT IS!  It Says  "Scallion"...SEE SCULLION"
            Man he cracked us up..LOLSpheramid Enterprises Architectural Woodworks
            Heck | Aug 20, 2008 04:07pm | #35
            LOL!
            Funny.
            By the way, with J Buck, I'm pretty sure it's pronounced with the small 'a'
        3. Howard_Burt | Aug 20, 2008 04:13pm | #36
          I have always heard it pronounced  "slaeke" with the  hard A on the west coast.
          1. Piffin | Aug 20, 2008 10:03pm | #37
            Hmmm, I'll bet there are more hard A's on the east coast than on the west coast!;)
            BillHartmann | Aug 20, 2008 10:39pm | #38
            Longhttp://www.merriam-webster.com/dictionary/slakesss-lake.
          3. Piffin | Aug 21, 2008 12:53am | #39
            Good! That is how I have always said it, but not because I knew.besides, I hate to have any slackers on the job. I want to see job applicants with wear showing on the knees of their jeans and the toes of their shoes, not the backs of their heels or the seat of their britches.
            JeffBuck | Aug 21, 2008 01:02am | #40
            ache ... like ... my back aches from not enough slaking.
            I like to slake ... allows me to slack.
                 Pittsburgh Pa
          5. Piffin | Aug 21, 2008 02:17am | #41
            Shall I bake you a cake to take?
            JeffBuck | Aug 21, 2008 02:30am | #42
            Sure.
            get a hold of Ralph and ask for Kathy's Orange Cake recipe.
            had some in Fla ... delicious!
                 Buck Construction
                 Pittsburgh Pa
          7. Piffin | Aug 21, 2008 02:50am | #43
            so it wasn't a shake-a-cake EZ bake cake mix?
          8. User avater
            JeffBuck | Aug 21, 2008 03:41am | #44
            hey ...
            just thot.
            now we have a daughter in the house ...
            I can finally get myself some of that EZBake Cake I been craving for years!
            haven't had any since the youngest niece grew up.
                 Pittsburgh Pa
  6. MSA1 | Aug 20, 2008 05:10am | #24
    Slake your grout. My tile guy is militant about it.
Fast, Accurate Wall Framing
