slap brush (crows foot) drywall texture
I just finished up taping 4 1/2 year addition on my house. It was kind of a big project 320 sq ft and all.
Now how do I go about putting on the texture. Will be doing walls and the ceiling to match the rest of the house.
Jim (remember me) at great white
Ok? I've applied many different textures, describe "crows foot"
I guess you start with a layer of joint compound rolled on the wall at a consistency of (pancake batter) and then start stomping with a brush.hope that helps also called panda paw,slap brush and crows footthanks
To start with I've tried the pre aplication and didn't like the results, i.e. drying, but a wide drywall knife works the best for me. So what I've done is: take a bucket of pre-mixed mud (the harder the better, texture scrapes off easily w/ say lightwieght) mix a small amount of water (adjust as needed) and your texture preference. I use washed (play) sand. I use a wallpaperers brush, I think it's called, the wide one, and just get artistic. Rules though ; material that has a long working time, dont make it (too) soupy, something that dries hard and a brush with the right soft/stiff ratio to not become limp or scrape off material. And lastly, have fun!
I had some guys put on a texture similar to the one your are describing (I think).
They used horsehair brushes, like a bench brush, about 16" long. They were pretty old and floppy. Mixed up the mud real wet and patted it on. Took quite a while. They did not put it on with a roller first, although I don't know why you couldn't.
John
