Slateman Question – Underlayment
Jeff_Clarke | Posted in General Discussion on February 28, 2008 01:33am
Or, to anyone –
What do you think of using Titanium synthetic underlayment with nail/staple caps under a new slate roof?   I’ve always specified 30# felt.   Would the plastic caps create a bit of an irregular surface under the slate?
TIA –
  1. jayzog | Feb 28, 2008 01:40am | #1
    I am no Walter, but have done a few slate roofs. The last one , I did exactly as you are suggesting , the slates I was using were irregular enough that the caps made no difference whatsoever.
    I never use the plastic caps on asphalt though because I think the would quickly show through.
  2. theslateman | Feb 28, 2008 02:14am | #2
    Jeff,
    In the past I've always used 30 lb. felt too - laid so it's  double covered lots of times.
    Recently I've started using Titanium too. I have a Hitachi button nailer I use for both felt and synthetics - it's better than the staple ones I feel.
    On most button locations it won't be directly under the very top of the slate so it's not an issue. Where the button and nail is directly under the slates top I simply use the nail claw on my slate hammer to pull the button off and sink the nail a little deeper.
    Walter
    View ImageView Image
      Jeff_Clarke | Feb 28, 2008 08:54am | #3
      Beautiful work Walter, and as always, thanks for the reassurance.
      1. theslateman | Feb 28, 2008 03:59pm | #6
        Jeff,
        How big a slate roof are you doing, and what kind of slate is it?
        Thanks for the kind words,   Walter
          Jeff_Clarke | Feb 28, 2008 04:50pm | #7
          I'd say about 18-22 squares, Vermont gray.
    2. seeyou | Feb 28, 2008 03:40pm | #4
      Hey Walter -
      I noticed they used Permafelt on the timberframe job. You see much difference between it and Titanium? It's about $30/roll cheaper than Titanium here.http://grantlogan.net/
      Today we's learnin' about rawks. They's all kinds of rawks. These [picks up rock] is rawks which you throw. These here [throws rock at Rusty] is rawks that you get hit with.  E.Cuyler
      1. theslateman | Feb 28, 2008 03:56pm | #5
        Grant ,
        The GC's laid the Perma felt using my Hitachi nailer - I helped sheath one side, but they dried it in.
        I will know more about it once we start laying slate there. I'll install my copper drip , then 2 courses of Grace in place of the synthetic felt.
        We've got a couple courses of Sieger snow guards to install to retain the snow from cascading down onto the future metal roof below.
        I'll be posting a lot of the RW slate install so I'll know better about the two types in awhile.
        Walter
