I need to put down PT 2X4 sleepers over a concrete slab in order to install a HW floor. What is the current ‘best practice’ for doing this (e.g. vapor barrier placement, method of securing sleeper to slab, etc.)
You might want to go to Building Science and look at their recommendations for finishing basements. They suggest forgoing the sleepers and instead putting down foam with plywood. There was an article in FHB sometime last year which showed similar details.
If you decide to go with sleepers, and will be attaching any type of flooring directly to the sleepers with anything other than stainless steel fasteners, you might consider using borate treated instead of PT. Borate treated, also known as blue wood, is resistant to microbial and insect damage but is not corrosive to steel. To fasten, I'd use a Hilti or Ramset type gun with 2.5 or 3 inch pins. One pin every 24" or so is usually more than adequate. You can rent these guns at most tool rental places. Is much faster than drilling/anchoring and makes a better connection.
I don't know about 'best practice', but I have laid tapered sleepers with PL Premium and Tapcons (ramset would probably work fine too). No VB, and I really think the fasteners were mostly acting like temporary clamps until the PL took hold. I don't see any problem with securing the subfloor with HD galv fasteners, especially if you use subfloor adhesive as well. Of course, I haven't been back to a job 20-40 years later to see if it held up, so who knows? As far as a VB, I have no clue, but I don't suppose it could hurt with hardwood going above it.
Edited 12/7/2007 1:27 am ET by K1500
You don't have hot water radiant heat in slab do you?
I've done the PT sleepers with tapcons and glue before, a couple of times, but if I had another to do another, I would use a product called dricore or similar
You need a VB - 8 mil poly
If you put down 1" insulation between the sleepers you'll avoid 'that hollow feeling'
Thanks to all for their input.
I pretty much have to install the sleepers to get the correct floor height. A 3/4" T&G subfloor is then specified with the HW laid over that. I'd like to use construction adhesive along with the fasteners to set the sleepers (Ramset rather than Tapcons...the thought of drilling all the holes makes my back ache already). I had been told to put a VB down first and then lay the sleepers which would eliminate the possibility of adhesive. Can I put the VB over the sleepers before the plywood is laid?
Also, where is the 'Building Science' info that was mentioned?
Sure.
I have a similar job coming up and I have a question about the Ramset nail. Will the nail head from the ramset keep the T & G subfloor from a tight and solid connection to the top of the sleeper?
not if you use a hot enough load to counter sink it...
don't try to drive the proud ones... cut them off with a grinder...
Done correctly with the proper load and depth setting on the gun (I use "red" in my Hilti gun), the nails will should be set below the top of the sleeper. Every once in a while one is left proud but a few smacks with the 28 oz Estwing takes care of that.
VB over sleepers.But there are a lot of ways to gain your elevation without sleepersGoogle for building science website
I am framing two houses on concrete slab. Plans call for 1 1/2 inch sleepers on the slab throughout the first floor of both houses. Slab is out of level and has many peaks and valleys. Plans call for the sleepers to be glued and shot down with hilti fasteners. I thought I was ahead of the game with these houses because the slab was the first floor and I got my normal square foot price, (without having to frame first floor system) Between having to cut each first floor stud to different lengths and planing and shimming sleepers I am atleast a week behind. One system I used in the past was to install vapor barrier, then 3/4 inch t&G foam then 1/2 osb (because of the stability) I used plywood clips on 16" centers between the osb panels and duct taped the seams. Installed 3/4" hardwood floors on top. Floor came out great, but did not sound the same as hardwood on second floor.
Years ago I prepped a floor by ripping 3/4 inch P.T. ply into six inch strips and nailing them down six inches on center diagonal to the run of the flooring. fastening was done by hand nailing with concrete nails over constitution adhesive. This floor is still tight after twenty years.
Edited 12/8/2007 5:45 pm ET by Gmo
Edited 12/8/2007 5:49 pm ET by Gmo
In the past I've laid down a vapor barrier, the sleepers then the plywood subfloor.
On the last project I did, a kitchen remodel, I used a dimpled plastic membrane product called Delta FL in lieu of sleepers. The manufacturer says it has an R3 insulative value. It went down real quick. I used Tapcons on 24" centers to secure the plywood through the membrane and to the concrete. The floor is really comfortable and fully supported across the entire surface.
