Sliding gate for fence?
Waters | Posted in Construction Techniques on August 16, 2007 11:54am
Do any of you brilliant minds have any suggestions for hardware or methods to build a sliding panel gate for your basic 6′ tall wood fence–8′ long panels between 4×4 posts?
I have a client with alley access to the back of the lot.  I am to rebuild fence and gates back there.  Has a shed near the fence.  Wants a std pedestrian gate 3′ wide but then also if one panel, say 7′ could slide back lateraly along it’s neighbor this would be great.
I see sliding gates–mostly chain link–around quite a bit, with the wheel ‘foot’ on the extended end.  I thought there would be commonly available hardware to build your own setup, but a few calls around locally yielded nothing and a lot of ‘that doesn’t work…’ comments…
Anyone have a suggestion for hardware, or how to rig it up to hang on channel/rollers on the two posts down the line?
Thank you
    BillHartmann | Aug 17, 2007 12:01am | #1
    Here is links for catalever and rolling sliding gates.
    Don't know why you could not use the wheels or rollers and brackets and mount a pipe on the back of a woodend fence.
    http://www.hooverfence.com/gatekits/cantilever-gates/
    http://www.hooverfence.com/catalog/cpage50.htm
    http://www.hooverfence.com/catindex.htm
  2. DanH | Aug 17, 2007 12:11am | #2
    With a gate cantilevered out seven feet you're going to need a steel frame for both the gate and the fixed fence it's attached to. Plus enough concrete on the inboard post (7-8 feet from the opening) to counterbalance the gate.
  3. davem | Aug 17, 2007 03:25am | #3
    i've been thinking about one of these too. why not put a beam across two posts and hang a barn door type rig from it? something like an I beam with rollers and the gate/door hanging from the rollers.
    my fence is 8 feet tall, so head room may be more of an issue for you.
    1. Waters | Aug 17, 2007 07:53pm | #6
      actually... that might be the best solution..  Barn door hardware is easily had but overhead only so maybe I should find an attractive way to make a 'arbor' out of the 3 high posts cross member and gate required to slide it overhead?
    SamT | Aug 17, 2007 07:27pm | #4
    The best thing I can come up with would be garage door track, two on the face of the panel that nest in two on the back side of the posts.
    A 7'x6' panel isn't that heavy that the client couldn't pick up one end to push it back until the tracks carried the weight.
    I would set short sections of tracks on the posts on the "Latch" side and let the panel track extend a bit past it's edge, so both sides of the panel were supported, then fab up a set of anti-lift blocks to set in the post tracks. Add a pair of matched holes for a lock and...
    SamT
    PeteDraganic | Aug 17, 2007 07:40pm | #5
    Whatever you do, don't add a wheel to the far end of the gate (or any other part thereof)... that is just cheesy, cheap, ugly and cumbersome in bad weather.
    To have a 7' slider, you'll likely need to build a panel that totals 14' or so.  Half would have pickets and the other half would be just frame to ride in rollers behind the stationary panel.
    I don't have time to assist in the search now but I am sure that you can acquire the rollers/pullies easily enough online.
    You will need 4 rollers and a total of 14' next to the opening for the gate to slide over to provide clearance in the opening.
    http://www.petedraganic.com/
