Sliding screen door replacement
JTC1 | Posted in General Discussion on September 17, 2009 11:28am
Have a customer with a ~30 yo. wooden door / window combination unit leading to his patio.
There is a in-swing door on the left side with two, fixed window units to the right.  All units – door / window / window – are the same size.
Outside of the door only there is a sliding aluminum screen panel which rolls on a track and will either cover the door opening or slide outside of the center window to allow passage. Single track top and bottom – notches in top and bottom of the screen door with internal rollers which glide along the track.
Glass has been replaced in all of the units with a thermopane panel.
No clue or markings to indicate manufacturer of screen or door / window unit.
Screen door frame is bent beyond straightening. I am trying to find a replacement — any clue as to a source?
Thanks in advance!
Jim
  1. rez | Oct 03, 2009 12:47am | #1
    Greetings Jim,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
    1. JTC1 | Oct 03, 2009 01:25am | #2
      Thanks rez.
      I may be hot on the trail via Andersen.
      Their Frenchwood sliding door series takes a screen door which is 77-9/16" H. x 35-1/2" W. x 5/8" T. The only reason I know the T is because I have one on my own house -- I believe that 5/8" is slightly thicker than the existing door at customer's house -- may not fit in the tracks.
      I think this may work - Andersen also has some other series of sliding doors which takes the same HxW - T is unknown at this time - if they are 1/2" -  I'm golden. Got distracted and need to get back on this job.
      Considering taking my screen door to the customer's house and trying it!
      Andersen doesn't seem to publish much info about the screens they provide with the doors -- just say "screen available" then reference by door model number.
      Still lookin'
      Jim Never underestimate the value of a sharp pencil or good light.
