Slip-Tongue Spline Question
jimmiem | Posted in General Discussion on August 1, 2013 04:02am
I’m installing 3/4″ solid t&g flooring. I’ve made up some spline stock for the backlaying work. I’ve read some info that recommends putting a piece of floor board, with its groove enveloping the spline, beside the flooring nailer to keep the spline at the correct angle as the double-splined board is being nailed. If I use this technique to keep the spline aligned is it necessary to glue the spline to the double-splined board? I’m sure that adding the glue wouldn’t hurt but does it really help in this situation? I can understand gluing the spline into one of the boards in an end-to-end joint where there won’t be a nail.
