Slipping Makita keyless chuck
PenobscotMan | Posted in Tools for Home Building on February 1, 2012 12:30pm
The keyless chuck on my Makita  cordless drill (6270D, 12V) has begun to slip very badly.  Is there a repair possible?  Should I replacwe the chuck?  Is it a job for a repair center?
  1. [email protected] | Feb 01, 2012 02:30pm | #1
    replace the chuck
    Open it all the way, and you should see some kind of lock screw in it.  Take that screw out, it will be a left hand thread, so righty loosey.
    Once the lock screw is out insert the biggest hex wrench you have that the chuck will hold in the chuck and tighten the chuck on it.  The chuck is right hand thread, so lefty loosey.  If it is stiff, rap on the end of the hex key a couple of times with a hammer and it should loosen up.
