Sloping or not sloping window base plate?
robbyve | Posted in Construction Techniques on October 16, 2023 07:14pm
Hello guys, I read about so many different ways to frame a rough window opening, and I wonder which suggestions you might have.
Somebody likes to slope the base plate, and somebody else says that it’s not necessary. What are your thoughts or ways to do it? I appreciate any suggestions. Thanks.
  1. calvin | Oct 16, 2023 09:05pm | #1
    Have never seen nor done a slope in the framing.
    Sill pan, yes.
    1. robbyve | Oct 17, 2023 08:57am | #2
      Thank you Calvin!
      1. calvin | Oct 18, 2023 01:27pm | #4
        I was brief before.
        I have laid a pc of beveled siding along that sill rough frame. Just enough slope for the homemade sill pan.
        1. robbyve | Oct 18, 2023 02:57pm | #6
          Thank you Calvin, Sounds good to me.
  2. vividkreations | Oct 18, 2023 08:35am | #3
    The decision to opt for a sloping or non-sloping window base plate hinges on your design and aesthetics. A sloping base plate can impart a contemporary, streamlined appearance while facilitating water drainage. Conversely, a non-sloping base plate retains a more classic look. To make the right choice for your project, take into account your architectural style, local climate conditions, and overall design objectives.
  3. bobbomax | Oct 18, 2023 02:19pm | #5
    It's the slope that's important- it helps any intrusive water get back out again- but it doesn't matter how you create it. You can add a piece of bevel siding like calvin, you can angle the top of the cripples and install the sill at an angle or you can bevel the sill itself with a belt sander or a grinder.
    If you're a finish carpenter by nature, you can run the sill through a jointer. If you have a table saw on site while you're framing, you can rip the sill at an angle. Some people create a dam on the interior side of the sill, which I disapprove of- the water won't get inside, but it may just sit there, allowing mold under the window.. I don't use the bevel siding method because how many sites have bevel siding readily available these days?
    It doesn't matter how you achieve the slope- just make sure it happens. Then make sure you create a water-tight sill pan so the water has to drain out. And don't nail or caulk or tape the bottom of the window, so the water has a path to the exterior. I just came across an interesting video from Josh Salinger, Birdsmouth Construction on Portland, OR, a notoriously rainy environment.
    https://www.finehomebuilding.com/2021/08/24/adu-rainscreen-and-window-integration
    1. robbyve | Oct 18, 2023 02:59pm | #7
      Bobbomax, thank you! I appreciated it!
Versatile Vise
