Slots for Undermount Slides
bmyyou | Posted in General Discussion on March 18, 2009 07:07am
Can I use 1/4″ baltic birch drawer bottoms with Blum undermount slides?  The attached pics from an article suggest 1/2 in. drawer bottoms to accomodate the metal clips that grab the drawer from the back, but aren’t most drawers that are using these types of undermount slides made with 1/4″ thick bottoms?  1/4″ will be more economical for a lot of kitchen cabinets.
  1. sapwood | Mar 18, 2009 09:04am | #1
    I've used 1/4" bottoms with 1/2" sides on numerous occasions. I fully house the bottoms in dados and let the back be full height. Then I cut a notch to accommodate the slide. A friend of mine kept the backs even with the lower edge of the bottom letting it rest in a rabbet. Either way is OK.
    A tip: you can gain another 1/4" interior width in your drawers by adding a small strip of 1/8" ply or other stock to the inside edge of the drawer below the bottom. The slide then thinks its adjacent to a 5/8" thick side and everything is alright in its world.
  2. gordsco | Mar 18, 2009 02:58pm | #2
    1/4" should be fine for small drawers. Considering the capacity of the undermounts, they will accept very large drawers.
    1/2' would be better on larger spans.
    1. bmyyou | Mar 18, 2009 03:27pm | #3
      So if the drawer back is notched then where does the metal tab stab into on the drawer?  In the picture that I attached the drawer bottom was a 1/2-inch thick so the metal tab was fit into a hole drilled into the drawer bottom, but if I use 1/4 inch birch for the drawer bottom there won't be enough "meat" of the drawer bottom ply for the metal tab to be set.
      1. gordsco | Mar 18, 2009 10:10pm | #5
        A sawcut or hole in the drawer back will accept the tab.
    xxPaulCPxx | Mar 18, 2009 08:03pm | #4
    Picture not so blindingly small!
    Tu stultus es
    Also a CRX fanatic!
    Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
