Small burn on sheet vinyl floor?
Matt | Posted in General Discussion on October 4, 2007 02:56am
How do I get a small burn mark off a vinyl floor – it’s Armstrong successor.  Looks like someone dropped a cigarette.   It’s not burned into the surface just a light brown mark (on a light grayish-beige floor) about 2x the size of the end of a pencil eraser.  Flooring guy said Magic Eraser, but it turned out to be not that magic…  Ideas?
I have a walkthrough with the customer tomorrow.
TIA
Edited 10/3/2007 8:37 pm ET by Matt
  1. DougU | Oct 04, 2007 04:18am | #1
    Matt
    do a cut in patch if you dont think the burn will come out.
    Pretty easy fix if you have a pattern.
  2. ponytl | Oct 04, 2007 05:38am | #2
    sandpaper? then clearcoat (automotive touchup paint or clear fingernail polish) if it won't sand out... might be able to hide it with a like color of automotive touch up paint or fingernail polish...
    not a huge fan of cutting & seaming  might be worse than when you started
    good luck
    p
      Matt | Oct 04, 2007 01:36pm | #3
      Thanks guys...
      Pony's method will be #1 this AM - that was along with what I was thinking...  It's such a small spot, but is noticable...
      If that doesn't work, the vinyl floor guys can do Doug's cut and patch thing - they would probably take a piece from under the stove... They say they have to use a piece from the same roll.  And their patch will be invisibal to any who don't know it is there.   I gotta wonder about that longevity of it though.  It does have a pattern so that helps a lot - it is like 4" tile squares.  I've been through this before but always before it was much worse damage.
