small estimating job today questions
daveytree | Posted in Construction Techniques on May 2, 2009 06:26am
Hey Guys,
Looking at a stud-um-up basement job today and possibly installing some ”DRI-CORE” floor, house is newer with the insulation blanket on the concrete wall half way down from top. Questions are; do I suggest to remove blanket and install ridgid insulation or install ridged and slide it underneath before studing. And can anyone tell me if that ”dri-core” floor is ”floating” why do they suggest to install floor and then anchor wall on top?and drywall ceilings [ map out plumbing etc]or drop ceiling?or other?
Thanks davey
  1. rez | May 03, 2009 06:59pm | #1
    Greetings davey,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
  2. rez | May 09, 2009 08:57pm | #2
    Let's run this thru again.
    bump
  3. rlrefalo | May 09, 2009 11:07pm | #3
    Use the extruded polystyrene on the walls, tape the seams, then metal studs. Follow the dricore instructions. It is sometimes attached to the concrete.
    Rich
