Small GFCI outlet
caseyr | Posted in Energy, Heating & Insulation on January 16, 2010 10:20am
Both my mom’s house and my house, each circa 1960, have older outlet boxes that are too shallow for a standard GFCI. The boxes have the top and bottom that go in a little over an inch and then have a 45 degree slope section down to the back, which is probably less than two inches high (don’t have one in front of me here…) A standard GFCI hits the sloped sections and stops the standard GFCI from going all the way in, so it stands out about 3/16th of an inch. Does anyone know of a GFCI outlet that can fit these older outlets? I asked at my usual electrical supply house and they just sort of shrugged. I would prefer not having to tear the wall up to remove and replace these old boxes. And, yeah, I realize that they are probably undersized by current code, but they are on 15 amp circuits and I assume they are grandfathered in if I can find a GFCI that will fit. On a different circuit, I put in a GFCI breaker in the panel but I would prefer to put them in the wall so I don’t have to go outside to reset them when they are tripped. Thanks, Casey
  1. DanH | Jan 16, 2010 11:08pm | #1
    Don't know of any small-sized
    Don't know of any small-sized GFCIs, but you have several other options:
    1) Put in a GFCI breaker on the circuit(s) involved.
    2) Get a box extender that "bumps" the box out about a half inch. Obviously, this "look" may or may not work in your case.
    3) Surgically remove the box and install a larger "old work" box. Not really as hard as it sounds, and no repair of the surface required (if you're lucky).
  2. cap | Jan 16, 2010 11:11pm | #2
    Casey,
    Welcome to my world! I see a lot of older housing with this situation. GFIs are all pretty much the same dimension. I usually replace the box. However, Arlington Industries has just announced a box extender that projects from the wall about 5/8", which would provide 5 cu inches and probably enough space for a GFI receptacle in most of the old 14 cu in boxes.
    Here's the link: http://www.aifittings.com/whnew146.htm
    Good luck,
    Cliff
    1. sbsmith49 | Jan 17, 2010 01:38am | #3
      If a box extention is used, could the original box be pushed back flush to the wall? An old box could be a pain to remove if it's also got junctions in it.
      1. DanH | Jan 17, 2010 10:27am | #4
        I think that would be hard to accomplish, and I doubt that there's an extension designed for that duty.
    popawheelie | Jan 17, 2010 11:09am | #5
    I just installed an exstender on a double gange box and I went with a plastic one.
    The reason I chose plastic is beacause the sides on the receptical won't short out on it.
    You would have to put somthing under the exstender for it to seat on.
    Then there is the cover not sitting against the drywall.
    Is there a cover that would work with a recpetical that is 3/16"-1/4" proud?
