smallest nail size to secure 1/4 ply?
jerseyjeff | Posted in General Discussion on June 2, 2005 06:01am
I want to secure 1/4″ birch plywood to studs (going through 3/8 ply),  and I was wondering the smallest nail size that would hold the wood up…  I am hoping for something less visible than my 15 guage nailer….  would a 23 gauge nailer/micropinner hold it up?
  1. Jay72 | Jun 02, 2005 09:52pm | #1
    I would try 18 ga. because 23's are headless. Are glue and a few hails an option? Jay
  2. FastEddie1 | Jun 02, 2005 10:18pm | #2
    Is it smooth ply, or grooved paneling?  If grooved, consider a narrow gage stapler with 1" staples through the grooves.
    1. jerseyjeff | Jun 03, 2005 08:45am | #3
      it is going to be smooth plywood,  I  could glue it up though...
        jhausch | Jun 03, 2005 01:14pm | #4
        PowerGrab, panel adhesive, etc, was my thought, too = then your pinner would be fine.
  3. RayMoore2G | Jun 03, 2005 02:50pm | #5
    We recently installed 1500 sq ft of veneer panelling on a 1/2" mdf core to a ceiling with 23 guage headless pins and construction adhesive. Try a mock-up first to ensure that the 1/4" is enough to hold the nail.
    Sphere | Jun 03, 2005 06:46pm | #6
    contact cement and a j roller, no nails.?
    The Morphine    s eems  to do no good at all..I'd run all the way if I would not fall...
    1. jerseyjeff | Jun 03, 2005 08:18pm | #7
      It is going over (or under depending on your perspective)  grooved plywood,  and I am not sure if contact adhesive would work.
        Sphere | Jun 03, 2005 09:44pm | #8
        I once used a melamine sheet ( like thick formica) over panelling..worked like a champ. Even over the glossy surface.  Spheramid Enterprises Architectural Woodworks
  5. reinvent | Jun 04, 2005 02:09am | #9
    Like the others said use a pinner w/ adhesive. But I would also suggest you shoot two pins at an angle to each other, so one helps the other resist pull out. Like and X in cross section.
