Hey all.
Had a gal ask me today why her new granite tops smelled bad. Asked the obvious about plumbing hook ups. She said that’s all good. I have nothing here. Any ideas?
Thanks all.
Were they sealed--maybe she's just smelling a sealer that hasn't cured completely?
Thanks to all who contributed. This was not my job and the question was asked by my dental technician, while I was in the chair. Anyway, I went to take a look, and , yep, it's plumbing. P-trap tail piece to wall was cracked on the top. No leak, just sewer gas.
Easy fix. Thanks again.
So, how does the dental tech look, if you have to, lie to us so we can live the fantasy No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
Yeah, and was there any cleaning of the pipes involved...
Bowchickawow-wow
obvious plumbing??
"Which side is hot?"
"Is this water as wet as it was before you started?"
"Did the plumber forget his crack?"
They always do.....lolNaive but refreshing !
wrong side up? ;)
"Preach the Gospel at all times; if necessary, use words." - St. Francis of Assisi
Was any other work done or just the granite?
What does it smell like? Fish, Chemicals, a stinky bunhole?
Years ago I stuck down a granite top with polyester resin that I did add enough catalyst to and the cabinet interiors smelled like polyester resin for a few weeks.
If it is a chemical smell I would look into the adhesive holding it down.
Sealer smell should dissipate very quickly.
Karl
Coating on outside of sink?
Silicone to attach sink?
Particleboard cabinet formaldehyde smell?
Silicone.
chinese drywall in Florida ...
Jeff Buck Construction
Artistry In Carpentry
Pittsburgh Pa
Bet that's it, they bedded the granite top in a few dabs of silly cone to keep it from floating away
If it is silicone, as others have suggested, the odor is sharp--like vinegar and should go away.
